Absolutely… kinda…
You can put our 28" Mattone Cupola on a cart with no problem. It will weigh less than 600lbs and you can roll it all over the neighborhood to your neighbors delight!
Our next size up is the 36" and that will take a bit more muscle to move as it weights in at 1000+ lbs. Not something you want to be rolling around on a cart.
Your next question will probably be, “Great! Where can I get a cart?”. While we don’t fabricate / sell carts for our ovens at this time, your local Metal Fabrication shop can make one for you. Simply Google Map “Metal Fabrication” and your Zip Code and several shops in your area will appear. Call around - get the best price!
