2 questions.
1 can I paint the chimney with high temp black paint?
2 the silicon that comes with it is to attach it to the chimney and seal the edges, correct?
It didn’t come with installation instructions
2 questions.
Hi Jay!
You are correct about the silicone. There is a step in the oven instructions, though I’m not near my computer right now. Definitely take a look. Mine worked well.
I suppose you could paint the pipe. Just make sure the paint is specifically for that purpose, and clean the surface thoroughly to get rid of any oils from the manufacturing process.
Hope you’ll post a photo or two when you are done!
