I have my slab formed onto my base blocks.
My question is when I pour my slab can I use high temp cement in the middle and pour it all at once and not put the void in the middle for the vermiculite
Or will the high temp not mix well with the regular cement?
Was going to do the outside edges with the 5000psi and the middle with high temp cement and just do it all at once. Then if I needed to level my fire brick I could use a small thin set of high temp mortar
You absolutely can use high-temp concrete mix for the entire slab. Or not at all. There’s no actual need to use high-temp concrete. As long as you’re following the general drift of the instructions, modified for doing a monolithic slab, heat never really affects the hearth slab itself. It’s an insulated slab for that reason. The standard bricks that form the frame for the firebrick hearth absorb heat, and the layers of firebrick/sand/insulative material that form the hearth are designed to make a thermal break between your hearth and the slab.
The important thing is to have the high-strength concrete (4000 to 5000 psi) throughout the slab, along with rebar to diffuse weight stress.
What you’re proposing might be okay, but I couldn’t speak to its performance. Also, you’ll be “bricking” yourself in if you fasten your firebrick in place with thinset. What happens if a firebrick cracks? How do you replace it? Ideally your brick are resting on a sand layer that allows easy leveling AND easy replacement.
Knowing that some time has passed since you posted this, I am curious what you decided.
