Hi
The instructions show the back of the oven being enclosed before removing the form? I’m thinking it might be easier to remove while the back is still open? Any thoughts on this?
Thanks!
Greg
Hi
Thanks!
Greg
Hi Greg,
For this one, search the forums on the phrase “removing the foam”. Some consider it the single most difficult task (after lifting the slabs), but there is a lot of wisdom from past builders there. I know at least a couple of builders chose to go that route, and there are other tips you should read as well.
Thanks Matt, I searched using other terms and didn’t see the relevant posts, your suggestion did the trick.
